Izolacja galwaniczna jachtu, ktoś stosuje? https://forum.zegluj.net/viewtopic.php?f=22&t=23850 |
Strona 1 z 1 |
Autor: | cine [ 10 lut 2016, o 13:01 ] |
Tytuł: | Izolacja galwaniczna jachtu, ktoś stosuje? |
Znalazłem ostatnio taka informację na stronie Sterling-Power: 1) Any earth problem on any boat or shore earth will increase the voltage in the common earth cable and dissolve - adversely affecting your boat by dissolving your anodes at an alarming rate (this could result in the total loss of all the metal on the boat below the waterline). 2) Because all the boats are now one, if you have a zinc anode on your boat, but the boat beside you does not or even worse, the marina has not put anodes on its structures (metal pontoons etc) then your boat's zinc, (or aluminium / magnesium) will protect all the structures and boats around you, resulting in dramatic zinc loss and expensive lift-outs to replace the zinc. For boats on inland waterways, if you have a magnesium anode and everyone else has zinc or no anodes at all, your magnesium anode will protect all. Ktoś stosuje u siebie zabezpieczenia (izolatory galwaniczne) czy taniej wymieniać anody? Pozdrawiam Wojciech |
