Teraz jest 6 wrz 2025, o 14:07
Utwórz nowy wątek Odpowiedz w wątku  [ Posty: 719 ]  Przejdź na stronę Poprzednia strona  1 ... 20, 21, 22, 23, 24
PostNapisane: 4 gru 2017, o 20:39
Jak już sobie goglotłumaczymy ( z konieczności ze szwedzkiego na inny pogański język - bo tłumaczenia automatyczne na polski odbiją się od dna dopiero za parę lat...) - to moją uwagę przykuł w pierwszym rzędzie sam opis zdarzeń. Troszkę goglotłumaczowi pomogłem a to co zainteresowało mnie najbardziej - podkreśliłem...):
Account of the course of events
ZJAWA IV was sailed across the Atlantic to the home port Gdynia in Poland, where she had not been for a long time. During the trip, a longer stay was held in Peterhead, Scotland, where some maintenance and machine replacement were carried out.
During the stay, discussions arose between the master and the ship's owner about the suitability of continuing the journey during the current season with the vessel in the current state (see section 1.4). The discussion ended when the master and a few other crew members traveled home at their own expense, whereupon the shipowner sent out replacements for crew members who had gone home.
After the ship had left Peterhead with the partially new crew - the weather deteriorated and the ship therefore went to Kristiansand, Norway, to wait there until the weather became better. Then they had problems with the electrical systems, the ship then went to Gothenburg to board an electrician. The electrician then followed the trip. In Gothenburg, the vessel stayed for two nights. They took the opportunity to carry out refueling.
In the middle of the day, December 5th, at. At 12.00 a watch shift was carried out.
Prior to that, the master has been on the double watch during the passage of the fairway Drogden and thus been in charge for 6-7 hours.
The shift shift took place just after completion of the passage through the waterway channel and lighthouse Drogden the vessel had passed on the port side on the course 170°.
The master handed over the responsibility to the mate, and also two lookouts (which interchanged between looking out and groomers) were changed.
Handover consisted, according to the master, that the mate received instruction to yaw after passage of Falsterborev, which would pass on the west side.
On the electronic chart, on the master computer the course was uploaded and planned that would take the boat in the lead towards Falsterborev.
The sail compilation was the mainsail and the fore-sail. The engine was running at half speed ahead, both for the sake of electricity supply, partly to reduce drift. The speed was 5-6 knots.
Immediately after the watch shift, the mate went down into the engine room for drainage of water, which took about half an hour. He also had to go down the engine room occasionally for drainage intruding water.
The navigation computer used for the ship's performance was restarted according to the logbook at. 12:43. This was done occasionally, according to the mate, because the computer sometimes closed itself.
Mate's intention was to pass close to land, but to have the cardinal marks (Westmarks¹) found on the chart on the ship's port side. This included crossing the Västerflaket west side. His intention with this was not to take the ship in the lane that heavier shipping used.
After a while, the ship passed a west cardinal mark, Viragogrund, on starboard (see figures 2 and 4). The Helmsman pointed out to the mate that this was wrong. The mate assigned immediately, by his own admission, a more westerly course, but pointed out that there was sufficient depth of five meters of for them to go free. The mate has stated that at this stage he was also occupied with drainage water in the engine room.
At 13:48 ZJAWA IV ran aground in position N 55° 21.1 'E 012° 48.2' and then get stuck few hundred meters south.
Wind and sea was later to move that ship further to the east (see AIS2 tracks in Fig. 2).
¹) Westmarks are located west of an obstacle (the fairway is west of the mark)
Za ten post autor Jaromir otrzymał podziękowanie od: Ryś
PostNapisane: 4 gru 2017, o 21:32
Otrzymał podziękowań: 2422
W punkt...
PostNapisane: 5 gru 2017, o 00:42
Ryczaca 40ska napisał(a):
większość raportu wydaje się być poświęcona kompasowi, deklinacji i dewiacji.
The location of the compasses and the knowledge of their function were lack temporary.
Pójdzie człek do Lidla kupić latarkę z a jakże magnesem i od razu na miel wchodzi :evil:
A miały być te jak im tam giepeesy, satelity, rakony, aisy i co tam jeszcze nawymyślali... :oops:
PostNapisane: 29 lip 2018, o 11:32
Podziękował : 105
Otrzymał podziękowań: 193
Wiadomo może jakie są plany względem jachtu? Remont będzie, a może trwa czy raczej Zjawa już nie popływa?
PostNapisane: 5 gru 2018, o 10:45
Dołączył(a): 31 sty 2016, o 19:10
Podziękował : 65
Otrzymał podziękowań: 28
Uprawnienia żeglarskie: takie sobie
Dzisiaj mija dwa lata od wejścia na mieliznę, czyli 5.XII.2016.
Wiadomo co dalej z jachtem?
PostNapisane: 13 sty 2019, o 21:39
Dołączył(a): 21 kwi 2018, o 15:39
Podziękował : 12
Otrzymał podziękowań: 12
Uprawnienia żeglarskie: Kapitan Jachtowy, RYA Yachtmaster
Rok od wejscia na mielizne wygladało to tak:
https://imgur.com/a/9dU94qj
Nie mam zadnych informacji czy stan ten uległa jakiejkolwiek zmianie, ale nie spodziewam sie by jacht jeszcze kiedykolwiek zszedł na wode.
Za ten post autor Jake otrzymał podziękowania - 2: hoopak, Ryczaca 40ska
PostNapisane: 15 sty 2019, o 21:46
Podziękował : 65
Wygląda jak by ktoś celowo usunął nazwę jednostki z burty....
PostNapisane: 15 sty 2019, o 22:14
Podziękował : 3105
Otrzymał podziękowań: 2710
Nazwa jest tam, gdzie zawsze była - na tabliczce na nadburciu.
SAM_7006.JPG [ 439.01 KiB | Przeglądane 11345 razy ]
PostNapisane: 16 sty 2019, o 05:39
Podziękował : 12
Falszburta z lewej strony został zniszczona gdy jacht leżał na mieliźnie. Z prawej burty nadal istnieje i tabliczka tez się zachowała. Widać ją na pierwszej fotografii w albumie, który wstawiłem.
Zjawa istotnie miała kiedys nazwe wypisaną biała farbą na burcie, w częśc dziobowej:
A także mniejszymi literami, razem z nazwa portu macierzystego w częsci rufowej:
Byly na kadłubie na pewno jeszcze w 2013, nie wiem dokładnie kiedy zniknęły, ale przypuszczam, ze podczas remontu w latach 2014-2015 i przed wyjsciem Zjawy w rejs na Karaiby nie zostały ponownie namalowane.
PostNapisane: 16 sty 2019, o 07:18
Podziękował : 890
Otrzymał podziękowań: 1953
Czy przepisy nie wymagają aby takiego oznaczenia? :?:
PostNapisane: 16 sty 2019, o 14:55
Podziękował : 12
U S T AWA
z dnia 18 września 2001 r.
Kodeks morski napisał(a):
Art. 12. § 1. Statek o polskiej przynależności oznacza się nazwą na dziobie,
z każdej burty i na rufie. Pod nazwą na rufie powinna być uwidoczniona nazwa
portu macierzystego statku.
§ 2. Właściciel nadaje statkowi nazwę i wskazuje port morski jako port
macierzysty statku. Nazwa podlega zatwierdzeniu przez dyrektora urzędu
morskiego właściwego dla portu macierzystego statku, w drodze decyzji
administracyjnej, z zastrzeżeniem § 2a.
[§ 2a. Nazwa statku morskiego używanego wyłącznie do celów sportowych
lub rekreacyjnych o długości kadłuba do 24 m podlega zatwierdzeniu, w drodze
decyzji administracyjnej, przez zarząd polskiego związku sportowego, o którym
mowa w art. 23 § 3.]
<§ 2a. Pod nazwą na rufie statku morskiego używanego do celów
sportowych lub rekreacyjnych o długości do 24 m powinny być uwidocznione
numer rejestracyjny, o ile został nadany, i nazwa portu macierzystego statku.
Nazwa statku morskiego używanego do celów sportowych lub rekreacyjnych
o długości do 24 m, rejestrowanego na podstawie ustawy z dnia 12 kwietnia
2018 r. o rejestracji jachtów i innych jednostek pływających o długości do
24 m (Dz. U. poz. 1137), nie podlega zatwierdzeniu.>
§ 3. Minister właściwy do spraw gospodarki morskiej określi, w drodze
rozporządzenia, tryb postępowania w sprawach nadawania i zatwierdzenia nazwy
statku, uwzględniając konieczność jego indywidualizacji.
§ 4. Minister właściwy do spraw gospodarki morskiej może określić,
w drodze rozporządzenia, inny niż wskazany w § 1 sposób oznaczania niektórych
statków, mając na względzie ich rodzaj, przeznaczenie i rodzaj żeglugi
PostNapisane: 16 sty 2019, o 18:59
Akhymmm... Mam nazwę na rufie, znaczy pawęży. Jako zwyczaj każe. Zresztą jest tam od półwiecza. I tylko tam.
Kiedyś był taki obyczaj, znaczy tradycja, że jacht żaglowy na dziobie nazwy nie nosi, w odróżnieniu od barek z węglem.
I nawet mazurskich łódek nie paskudziłem, iirc.
A jak tak i dziś spojrzeć wokoło po angielskiej elegancyi, raczej wszyscy tradycyjni podpisani na rufie.
A szczerze mówiący, to gdyby ktoś siem czepił że nieprzepisowo, prędzej zdejmę naszą banderę - co noszę patriotycznie - niżbym spostponował urodę klasycznej Damy... :-P
PostNapisane: 17 sty 2019, o 00:43
Podziękował : 12
Nie jestem przekonany dlaczego nazwa jednostki na dziobie to profanacja estetyczna...
Zawsze wydawalo mi sie ze z nazwy mozemy byc dumni, a nie sie jej wstydzic. Szanse na pomylenie jachtu z barka z weglem nie sa w mej ocenie zbyt duze i sa cechy latwiejsze do ich rozroznienia niz obecnos (lub jej brak) nazwy na burcie :rotfl:
Nie znam przespisów ani regulacji brytyjskich, ale czesc znanych jednostek angielskich nosi nazwe na burcie w czesci dziobowej. s/y Johanna Lucretia, s/y Queen Galardiel. Z drugiej strony s/y Excelsior ma na burcie numer LT472 i to dopiero na wysokosci want fokmasztu, s/y Earl of Pembroke, nazwy na dziobie nie ma wcale.
Co do Zjawy, kodeks nie reguluje sposobu oznakowania, minimalnej wysokości liter itp. Byc moze drewniana tabliczka na falszburcie jest wystarczajaca.
PostNapisane: 17 sty 2019, o 00:52
Ano właśnie, wymieniasz cargo. :mrgreen:
A widzisz nazwę na tym dziobie? :lol:
Ale jak to dzisiej które co majo we zwyczaju to nie wnikam, kto to wie, zresztą. Wolnoć, Tomku.
O, tempora.
O, mores!?
:-P
PostNapisane: 17 sty 2019, o 04:41
Podziękował : 12
Cóż, tak jak nie kazdemu dane jest miec słuch muzyczny, byc moze mnie nie dane jest dostrzec piekno braku nazwy. Ale chyba umiem z tym zyc.
PostNapisane: 17 sty 2019, o 04:50
Znaczy, brak Ci zmysłu regatowego... nie powiem, mnie też. ;)
Ale to jeszcze nie powód by siem przyznawać, a już tu w towarzystwie... :-P
PostNapisane: 5 gru 2019, o 19:03
Podziękował : 65
dzisiaj, 3 lata temu ....
PostNapisane: 11 wrz 2020, o 13:34
Podziękował : 1963
Oglądałem w lipcu i sierpniu przez płot Zjawę stojącą na kobyłkach, nic się wokół niej nie dzieje...
Zajmuje tylko miejsce w darłowskiej stoczni. :-(
Na wodzie stoją i niszczeją dwa inne stalowe kecze, jeden to chyba "Wojewoda Koszaliński".
Za ten post autor Kurczak otrzymał podziękowanie od: Ryczaca 40ska
PostNapisane: 11 wrz 2020, o 14:16
Podziękował : 455
Otrzymał podziękowań: 766
Te kecze to wzięły ci się od kaczki :-D
Seba
PostNapisane: 11 wrz 2020, o 16:15
Podziękował : 1963
Masz jakiś uraz do zwierzątek, myszek, kaczuszek ? :lol:
https://pl.wikipedia.org/wiki/Rigel_(typ_jachtu)
Drugi, stojący burta w burtę z tego co pamiętam także kecz ale nazwa raczej z niczym mi się nie kojarzyła, portu macierzystego na rufie nie było widać.
Zjawa IV to również kecz.
Za ten post autor Kurczak otrzymał podziękowanie od: Seba
PostNapisane: 11 wrz 2020, o 19:47
Ze wszystkich keczy najbardziej lubię keczup :mrgreen:
PostNapisane: 5 lut 2021, o 21:44
Podziękował : 65
4 lata.
Coś chyba Zjawę IV czeka ten sam los co Pośwista.
PostNapisane: 6 lut 2021, o 11:01
Podziękował : 890
4 lata.
4 lata i 2 miesiące. To był grudzień.
PostNapisane: 12 lut 2021, o 08:22
Podziękował : 65
o taka ciekawostka :
"Uregulowano stan prawny jachtu s/y Zjawa IV–na podstawie umowy darowizny nr 4/2019 zawartej pomiędzy Skarbem Państwa -Ministerstwem Gospodarki Morskiej i Żeglugi Śródlądowej a ZHP zawartej w dniu 13 sierpnia 2019 roku staliśmy się właścicielem Zjawy IV"
z
https://work.zhp.pl/wp-content/uploads/ ... lcenia.pdf
tylko remont jakiego jachtu chodzi tutaj ???
https://warszawa.wyborcza.pl/warszawa/7 ... demii.html
PostNapisane: 12 lut 2021, o 10:02
Podziękował : 65
Z drugim naszym jachtem nie mieliśmy szczęścia od początku tej kadencji. Odziedziczyliśmy go jako wrak po zdarzeniu morskim. Do lipca 2019 r. „Zjawa IV” nie była formalnie własnością ZHP – użytkowaliśmy go jeszcze w komunizmie, ale – jest to ciągła zmora kolejnych zarządów ZHP po transformacji ustrojowej – we właściwym czasie nikt nie zadbał o sporządzenie i zabezpieczenie dokumentacji, która formalnie potwierdzałaby, że ZHP jest jej właścicielem. Dlaczego zależało nam na tym, żeby wrak jachtu stał się naszą własnością? Ano dlatego, żeby raz na zawsze zamknąć kwestię tego, czy ZHP będzie ponosił wobec Skarbu Państwa odpowiedzialność za zniszczenie jachtu, który stanowił własność Skarbu Państwa. Porozumienie przenoszące własność Zjawy na ZHP nie pozostawia wątpliwości, że Skarb Państwa nie będzie od ZHP dochodził żadnych rozliczeń z tytułu zniszczenia jachtu.
Gdy „Zjawa IV”, a dokładnie jej wrak, stał się własnością ZHP opracowaliśmy plan dalszego postępowania i przedstawiliśmy go zarówno Centralnej Komisji Rewizyjnej ZHP, jak i Radzie Naczelnej ZHP. Czy mogliśmy działać w tej sprawie szybciej? Tak, mogliśmy, co przyznajemy. Czy mieliśmy plan, aby sprawę zakończyć? Tak, mieliśmy. Także przed ostatnią zbiórką Rady Naczelnej ZHP podjęliśmy kolejne kroki zmierzające do uregulowania sprawy Zjawy. Rozwiązanie zgodne z postanowieniami umowy darowizny wraku zawartej ze Skarbem Państwa oraz jednocześnie ekonomicznie realne wymaga odstępstw od zasad nadzoru właścicielskiego przyjętych w ZHP. Pozyskanie partnera gospodarczego do remontu jachtu oraz wypracowanie rozwiązań bezpiecznych dla ZHP to procedura niestandardowa, niełatwa, więc i niebłyskawiczna
z
https://m.facebook.com/story.php?story_ ... 0560665199
Za ten post autor Ryczaca 40ska otrzymał podziękowanie od: Stara Zientara
PostNapisane: 5 mar 2021, o 19:28
Podziękował : 461
Otrzymał podziękowań: 482
https://zeglarski.info/artykuly/nowa-sp ... -zjawe-iv/
Za ten post autor markrzy otrzymał podziękowanie od: Ryczaca 40ska
PostNapisane: 5 mar 2021, o 20:02
Podziękował : 65
markrzy napisał(a):
https://zeglarski.info/artykuly/nowa-spolka-odbuduje-zjawe-iv/
ciekawe jak to się skończy. Z linka "
chcemy go w miarę możliwości szybko zwodować i przeholować ze szczelnym kadłubem, na razie bez silnika i steru, do nowej przystani POLsail w gdańskiej Twierdzy Wisłoujście. "
. Czyli stanie sobi tam gdzie sobie Poświst stał a jak to się dla Pośwista skoczyło to chyba wiemy.
PostNapisane: 21 mar 2021, o 17:01
https://wypadkijachtow.pl/zjawa-iv-2016 ... im-baltyk/
Za ten post autor Zbieraj otrzymał podziękowania - 2: markrzy, Ryczaca 40ska
PostNapisane: 3 paź 2021, o 21:54
Podziękował : 137
Otrzymał podziękowań: 303
Parę uwag po lekturze postanowień IM. Nie jestem prawnikiem i o ich jakości a w szczególności o uzasadnieniu nie będę się wypowiadał. Jednak bardzo chciałbym się dowiedzieć na jakiej podstawie stwierdzono skuteczne wprowadzenie przez armatora Systemu Zarządzaniem Bezpieczeństwem;
skuteczne podjęcie przez armatora niezbędnych działań organizacyjnych w celu ograniczenia prawdopodobieństwa uniknięcia podobnych wypadków w przyszłości (opracowanie i przyjęcie w dniu 14.02.2017 r. Systemu Zarządzania Bezpieczeństwem na jednostkach pływających CWM ZHP Gdynia)
Drugie pytanie dotyczy samego raportu SHK oraz historii „safety recommendation” skierowanego jak by nie było do naszej administracji czyli UM. Czy IM znane są dalsze losy tego zalecenia? Polecam lekturę;
https://www.havkom.se/assets/reports/RS ... gstate.pdf
Jestem również zainteresowany oficjalnym tłumaczeniem tego raportu. Czy harcerze/żeglarze lub inni zainteresowani a nieznający zbyt dobrze języka angielskiego mają dostęp do takiego tłumaczenia?
Tak jak już wcześniej napisałem. PKBWM nie uznała za stosowne zainteresować się pracą swoich szwedzkich kolegów i całą ich prace wyrzuciła do kibla a IM niewiele myśląc spuściła wodę i wszyscy są zadowoleni z bardzo dobrze spełnionego obowiązku.
Krzysztof
Za ten post autor SIRK otrzymał podziękowanie od: Ryczaca 40ska
Użytkownicy przeglądający ten dział: cors, Wojtek Bartoszyński i 40 gości
